3.2. Two-dimensional fluidized bed, Two-fluid Model (TFM)
Geometry |
10 cm x 30 cm |
Mesh |
20 x 60 |
Solid diameter |
Solid density |
Gas velocity |
0.25 m/s |
Temperature |
Pressure |
3.2.1. Create a new project
On the main menu select
3.2.2. Select model parameters
On the Model pane:
Solverdrop-down menu.
3.2.3. Enter the geometry
2 DimensionalcheckboxEnter
3.2.4. Enter the mesh
20for the x cell valueEnter
60for the y cell value
3.2.5. Create regions for initial and boundary condition specification
visualize the results.
ColorbuttonEnter
xmaxormaxin theTo XfieldEnter
zmaxormaxin theTo Zfield
FromandTofields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From YandTo Yshould equalymin, defining an XZ-plane.Enter a name for the region in the
Namefield (“inlet”)
FromandTofields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From YandTo Yshould equalymax, defining an XZ-plane.Enter a name for the region in the
Namefield (“outlet”)
3.2.6. Create a solid
On the Solids pane:
3.2.7. Create Initial conditions
OKbutton.
3.2.8. Create Boundary conditions
3.2.9. Change numeric parameters
3.2.10. Select output options
VTKsub-paneSelect the “Background” region from the list to save all the cell data
OKto create the output
Volume fraction,Pressure, andVelocity vectorcheckboxes on theFluidsub-sub-pane
3.2.11. Change run parameters
3.2.12. Run the project
3.2.13. View results
3.2.14. Increase grid resolution
