3.7. DEM granular flow chutes
1.75 m x 0.94 m x 0.2 m |
20 x 20 x 10 |
12.5 mm (0.0125 m) |
3.7.1. Create a new project
3.7.2. Select model parameters
On the Model pane:
Disable Fluid Solvercheckbox.
3.7.3. Enter the geometry
primitives->cylinderEnter
30for the cylinder resolution
Slice the tube in half:
Y Lengthto1.2m
Rotate the chute:
transform)Enter a value of
120in theRotation Zfield
transform1)Enter a value of
70in theRotation Zfield
Press the
3.7.4. Enter the mesh
On the Mesh pane:
Backgroundsub-pane
20for the x cell valueEnter
20for the y cell valueEnter
10for the z cell value
3.7.5. Create regions for initial and boundary condition specification
Select the Regions pane.
3.7.6. Create a solid
On the Solids pane:
On the DEM sub pane:
check the
3.7.7. Create Initial conditions
3.7.8. Create Boundary conditions
OKOn the
Select regiondialog, select “No Slip Wall” from theBoundary typecombo-boxSelect the “walls” region and click
3.7.9. Select output options
VTKsub-paneSelect
Particle Datain theOutput typecombo box.Select the “Background” region from the list to save all the cell data
3.7.10. Run the project
3.7.11. View results
