3.6. Three-dimensional DEM hopper
5 cm diameter hopper |
10 x 25 x 10 |
0.003 m |
NA |
NA |
3.6.1. Create a new project
3.6.2. Select model parameters
Solverdrop-down menuCheck the
Disable Fluid Solver (Pure Granular Flow)checkbox.
3.6.3. Enter the geometry
applyto build the hopper stl filePress the
Autosizebutton to fit the domain extents to the geometryPress the
3.6.4. Enter the mesh
10for the x cell valueEnter
25for the y cell valueEnter
10for the z cell value
3.6.5. Create regions for initial and boundary condition specification
namesuch as “walls”Check the
Select facets (STL)checkbox to turn the region into a STL region. The facets of the hopper should now be selected.
the Y direction by:
Slice facets.Check the
Filter facets based on normalscheckboxEnter a vector pointed in the positive
3.6.6. Create a solid
On the Solids pane
In the DEM sub-pane, check Enable automatic particle generation checkbox
3.6.7. Create Initial conditions
3.6.8. Create Boundary conditions
the hopper by:
Select regiondialog, select “No Slip Wall” from theBoundary typedrop-down menuSelect the “walls” region and click
3.6.9. Select output options
OutputpaneOn the
VTKsub-paneOn the “select region” dialog, select “particle data” from the
output typedrop-down menuSelect the “Background” region from the list to save particle data over the entire domain
DiameterandTranslational velocitycheckboxes
3.6.10. Change run parameters
Change
Stop timeto2.0secondsChange
Time stepto1e-3secondsChange
3.6.11. Run the project
Rundialog, select the default solverClick the
3.6.12. View results
